![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
front end damage mystery
I hit some loose gravel last week on the front right with my Hatchback,07.
I made a major racket. Ever since I have a knocking sound in the front but no one has been able to ID the problem yet. It sounds like the soft knocking of a loose muffler but the mechanics say nothing is loose and they were underneath it in a service pit.It also has a similar knock to a bad water pump bearing but no change yet in water temp. via scan gauge. It seems to lessen when I press on the gas. There is also some tinny metal scraping off and on which I think might be a broken shock but the car doesnt look crooked at all. The sound is in the front. Anyone have an experience with something similar.???? thanks
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Stone in the hubcaps?
Apexing Egg!!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#4 | |
Check the front brake shield on that side. |
another mechanic couldnt see what it was but said it sounded bad. Anyone have a link to pics of the motor mounts on the hatchbk. I might have broken one..You cant see anything
on these micro rigs.... |
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
where in the usa are you? if you are close to some of us that spend time under vehicles, then we could take a look under there, maybe with a comparison to a "known good" yaris... that will probably be what it takes to make the final diagnosis unless that mechanic that you took it to is blind...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
Hitting gravel = broken motor mount?
I was picturing an inch or two of gravel on the ground - now I'm guessing you ran into a large pile. There are about a million places gravel could lodge itself or damage in a car to make noise. Diagnosis over the internet is improbable.(at least without pictures and a much better explanation) |
![]() ![]() ![]() Drives: 1986 Toyota Corolla Join Date: May 2009
You might have a rock lodged in your tire tread.
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
Pull off your front tires and check behind the brake rotor, I get rocks in mine all the time. It makes a horrible noise.
the car shudders when its started. Maybe Schwab can figure it out.
it turned out to be a stone about 1.5 inches wedged between the transmission and the frame. It really made the car shudder when started.Now its fine.yee haw.
I love momentum.
Holy crap, good find!
| Word Association | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 7373 | 10-04-2011 10:43 PM |
| Front end mask | RocknRollRon | Items for Sale by private party | 7 | 09-02-2007 06:12 AM |
| Bra or front end protector? Yaris S | N9QGS | Cosmetic Modifications (Exterior/Interior) | 6 | 07-13-2007 08:29 AM |
| FT: Polar white Front End in So. Cal | Walter | Items for Sale by private party | 33 | 01-16-2007 12:11 AM |
| For trade, polar white front end | Walter | California | 0 | 01-08-2007 11:38 PM |
