Old 06-03-2009, 02:31 PM   #1
bronsin
bronsin's Avatar
Looking at the switches, EB1900-ND, I see it takes a half inch hole to mount. Id like to do the four switch version. Im thinking this could crowd the hole behind the panel. And it would be difficult to drill 4 half inch holes in the panel that close together. Im thinking of using a smaller switch which takes a .19 inch mounting hole. The eb1900 is rated 3 amp @ 125VAc. The smaller switch is rated .5A @ 125VAC. Will this be enuf? Thanks!
Old 06-03-2009, 03:40 PM   #2
The current draw in negligible, so any switch will work. Fitting four of the ones I used is tricky. I drew it up in CAD and found that I only had a margin of about 1/8" for the four switches to fit through the hole behind the trim piece. One thing I just realized that I didn't check how much that hole can be widened.
Old 06-03-2009, 03:53 PM   #3
bronsin
bronsin's Avatar
The hole can be widened A LOT, maybe half an inch on the radius. The catch is the plastic material is like an inch thick. It would make a huge mess to remove it.
PS the switch Im thinking of using is Digikey EG2021-ND.
Old 06-03-2009, 04:06 PM   #4
The hole can be widened A LOT, maybe half an inch on the radius. The catch is the plastic material is like an inch think. It would make a huge mess to remove it.
That's the nice thing about mounting the switches to that removable trim piece - All of the drilling mess happens on the bench instead of in the car.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
