Vroom Vroom Beep Beep
I checked all the fuses and nothing
Ever blown out an R-200 diff god know's I have
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
Hmmm....well. If you're still brave. Get a voltage tester, take off the front panel covering the wiper motor, turn the key, flip the wiper switch and see if a current is running. If it is, them motor is dead. If it isn't, then there is break in the current and figure out from there (maybe something wrong at the wiper switch end?).
The evil method would be to rent a Yaris, take it to your garage, switch the parts, and return the car. But you didn't hear that from me. Added note: sorry for the long run-around. Its better to rule out step by step. Hate for you to run and buy a new motor when all you needed was a wiper switch or some other major part. Last edited by texkid; 06-05-2009 at 02:48 AM. Reason: Adding a side note. |
I would think the switch is more likely the culprit than the motor. If the motor/gearbox failed mechanically it would keep taking out the fuse. The front wiper, rear wiper, and washers are on separate fuses (15A WSH {front and rear washers}, 25A WIP {front wiper}, 15A RR WIP {rear wiper}).
If the 25A WIP fuse is not blown, I would try bypassing the front wiper switch. To do so, on the stalk connector, jump the +B to +1 wires. Black (pin 2) to Blue (pin 3) using a small stiff piece of wire. Wiper Conn Detail.jpg |
If you still have some warranty let the dealer deal with it.
Could also be a malfunctioning activation switch on the steering column ,you might want to find out before you blow money on the motor only to find out that it still doesnt work.Like texkid said |
| Crack on the windshield | zyovka | General Yaris / Vitz Discussion | 9 | 12-22-2021 10:10 AM |
| Windshield cleaning? | missmieke87 | Wash, Wax, Detailing, Exterior Repairs | 21 | 10-28-2011 11:17 PM |
| Windshield Treatment Problem | Yaris Newbie | Wash, Wax, Detailing, Exterior Repairs | 20 | 12-12-2008 01:43 AM |
| chip in windshield | deebrown | General Yaris / Vitz Discussion | 0 | 04-04-2007 12:58 AM |
| Annoying front windshield hazing/fogging with wipers! | Jem_hadar | General Yaris / Vitz Discussion | 11 | 12-15-2006 03:53 PM |
