Old 06-05-2009, 06:44 AM   #1
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Originally Posted by markitect View Post
https://www.silabs.com/products/mcu/...C8051F0xx.aspx
The dev kit is under $100
someone should scope the signal to confirm its really a DC signal though, wish I had some more free time.
Hmm, that micro doesn't look too bad. I'll see if I can get a sample.
I know that on my Mazda I was able to pull APS voltage from the OBD-II PIDS, and it was a 0-5V DC signal. I'll see if I can hook my laptop up to the Yaris this weekend and confirm that it works that same. By the way, you really don't need a whole engine to test this, just the accelerator pedal.
bearda is offline   Reply With Quote
Old 06-05-2009, 08:22 AM   #2
The only bad thing about that 8051 based mcu is the amount of support circuitry required. The PICs require far less.
The reason I would like to have a running engine to bench test with, is that I see taking this to the extreme of actually using the microcontroller to even fire the injectors. The injectors are controlled by a PWM signal. For Turbo and SC cars the system could then meter more fuel as required (by tweaking the PWM duty cycle).
