![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Or are you confusing the "sandpaper" feel of the ABS with something bottoming out.
But Yeah - tire pressures? |
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Who said Yaris was slow?
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
not recommended... you'll be HATING life.. instant brake lockup
Break'em off some.
Break'em off some.
Tamago is right, you could be on the bump stops. My car never exibits this behavior and I am lower than you are.
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
Mine has no abs and the only time I lock up the brakes is when I'm being an idiot.
Another thing to check is the plastic inner-fender liner. I had a similar problem and it turns out I was rubbing on it (with stock wheels and tires) because it had popped in. I just pushed on it to pop it back into place. Mine was never in an accident or anything, I assume its from autocorssing. |
have you driven an abs equipped toyota with the relay removed? the brake booster is especially touchy on abs equipped models.
#10 | |
Break'em off some.
Yes if you start stabbing at the brake pedal, you are going to lock the wheels. |
| rubbing up front under heavy breaking | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-12-2009 12:23 PM |
| heavy braking | regal | General Yaris / Vitz Discussion | 8 | 05-12-2009 11:45 AM |
| ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck | trini_per4mance | Items for Sale by private party | 0 | 12-20-2008 12:16 AM |
| A little Culture (heavy on the bandwidth) | GeneW | Off-topic / Other Cars / Everything else Discussions | 0 | 11-21-2008 04:50 AM |
| How Heavy is the flywheel? | jouslee | DIY / Maintenance / Service | 12 | 02-22-2007 02:18 PM |
