![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Who said Yaris was slow?
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
not recommended... you'll be HATING life.. instant brake lockup
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Break'em off some.
Tamago is right, you could be on the bump stops. My car never exibits this behavior and I am lower than you are.
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
Mine has no abs and the only time I lock up the brakes is when I'm being an idiot.
Another thing to check is the plastic inner-fender liner. I had a similar problem and it turns out I was rubbing on it (with stock wheels and tires) because it had popped in. I just pushed on it to pop it back into place. Mine was never in an accident or anything, I assume its from autocorssing. |
#8 | |
Apexing Egg!!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
have you driven an abs equipped toyota with the relay removed? the brake booster is especially touchy on abs equipped models.
#10 | |
Break'em off some.
Yes if you start stabbing at the brake pedal, you are going to lock the wheels. |
ahh, well you're good then!
| rubbing up front under heavy breaking | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-12-2009 12:23 PM |
| heavy braking | regal | General Yaris / Vitz Discussion | 8 | 05-12-2009 11:45 AM |
| ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck | trini_per4mance | Items for Sale by private party | 0 | 12-20-2008 12:16 AM |
| A little Culture (heavy on the bandwidth) | GeneW | Off-topic / Other Cars / Everything else Discussions | 0 | 11-21-2008 04:50 AM |
| How Heavy is the flywheel? | jouslee | DIY / Maintenance / Service | 12 | 02-22-2007 02:18 PM |
