Old 06-06-2009, 02:52 PM   #1
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
GT17 too small?
Just curious. If so, what size? GT20, 25, 28?
Plan to start at 7psi and maybe graduate to 8.
No engine management, for now
No intercooler right away, may do top mount later
TC or 1ZZ injectors
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 06-06-2009, 05:09 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Get the GT2554R
That is the smallest garrette BB turbo.
You can get it new from $800-$900
You can get an even smaller Journal B turbo like a GT20 but eventually when you want to upgrade your set up, those units just won't put out any top end power...
You can get easily over 200 whp with the GT2554 and still have a pretty fast spool up time.
Old 06-06-2009, 05:21 PM   #3
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Thanks! Any recommendations on a place to buy?
Old 06-06-2009, 05:29 PM   #4
CASTREX
CASTREX's Avatar
Ask Garm.
I recently bought the GT25 he took out of his car...
Old 06-06-2009, 06:07 PM   #5
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Will do. Thanks
Old 06-06-2009, 06:18 PM   #6
That's a good choice. 7 psi, no I/C and no management might give you 140-150 whp, I think.
Old 06-06-2009, 06:58 PM   #7
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
That would be plenty of power. Now the question would be, how safe is that set up?
If I knew the 1nz-fe volumetric efficiency and the air flow at a given rpm, then I could read the compressor maps and decide. Anyone know?
I've been looking through some honda and scion forum classifieds, I see alot of t3/t4s for sale. I'd really prefer no lag or very little obviously. A friend of mine had a t3/t4 on his B16 but I can't remember if he had lag or not. Plus vtec made it hard to tell anyway I'm sure. Hope to come across a GT25 soon.
Old 06-06-2009, 07:29 PM   #8
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
If I can get away without detonation and being lean, which I think is feasible, I think I'll be fine. I'm here to gain knowledge though so I'm open to suggestions. I may go with a TMIC, depending if I can find one designed to my likings.
Old 06-07-2009, 01:51 AM   #9
No intercooler and no engine management? Are you senile?
I ran my turbo without management for nearly a year. Tamago ran his with no issues either. It is possible.
The T3/T4 will create way too much lag at low boost; it's just not the right choice for your intended application.
Old 06-07-2009, 12:14 PM   #10
Real world experience is what makes it good or bad. I am pointing out two cases where it worked fine. Do you have a real-world case where a Yaris (or other 1.5L) failed from running a low-boost application without management?
Your sarcasm does not contribute to the discussion -- your real experiences do!
Old 06-07-2009, 01:05 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
jeemee, want to buy my charge pipe/intercooler? you'll need a shorter battery however.
Old 06-07-2009, 01:18 PM   #12
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
It goes on and on...
and on and onnnn
Strangers, waiting
Up and down the boulevard!!!!
Their shadows
Searching in the nighttttt
Old 06-07-2009, 01:24 PM   #13
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Tamago, I'd like to see some pictures. Definitely interested.
Old 06-07-2009, 03:29 PM   #14
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
My objections aren't about boosting a stock motor, its about boosting any motor without the proper supporting modifications of which the primary, and most crucial component is engine management.
The Spectacle is offline   Reply With Quote
Old 06-07-2009, 03:34 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
at 7 psi the only thing you should be concerned with is a cool IAT and enough fuel, both of which can be achieved without throwing money into complicated engine management
Old 06-07-2009, 03:39 PM   #16
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
spectacle FTL
Old 06-07-2009, 03:40 PM   #17
Morgan
Morgan's Avatar
Drives: 07 MM LB
*subscribed*
Old 06-07-2009, 03:41 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Morgan View Post
*subscribed*
tell us, oh wise one!
before the Spectacle makes a Himself out of himself any further
Small cars stacked up at dealerships. freeridelectric New YARIS Purchase Forum 11 04-24-2009 08:23 AM
Small car's name? yaris-me Off-topic / Other Cars / Everything else Discussions 13 03-29-2009 02:43 PM
Small science fiction story I wrote which includes the Yaris. :) john21031 Off-topic / Other Cars / Everything else Discussions 3 11-21-2008 12:57 PM
How Small Would You Go? Nigal General Yaris / Vitz Discussion 26 06-15-2007 08:44 PM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 04:17 PM
