XBL: Jeemee Ghost
GT17 too small?
Just curious. If so, what size? GT20, 25, 28?
Plan to start at 7psi and maybe graduate to 8. No engine management, for now No intercooler right away, may do top mount later TC or 1ZZ injectors
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers |
Who said Yaris was slow?
Get the GT2554R
That is the smallest garrette BB turbo. You can get it new from $800-$900 You can get an even smaller Journal B turbo like a GT20 but eventually when you want to upgrade your set up, those units just won't put out any top end power... You can get easily over 200 whp with the GT2554 and still have a pretty fast spool up time. |
XBL: Jeemee Ghost
Thanks! Any recommendations on a place to buy?
Ask Garm.
I recently bought the GT25 he took out of his car... |
XBL: Jeemee Ghost
Will do. Thanks
That's a good choice. 7 psi, no I/C and no management might give you 140-150 whp, I think.
XBL: Jeemee Ghost
That would be plenty of power. Now the question would be, how safe is that set up?
If I knew the 1nz-fe volumetric efficiency and the air flow at a given rpm, then I could read the compressor maps and decide. Anyone know? I've been looking through some honda and scion forum classifieds, I see alot of t3/t4s for sale. I'd really prefer no lag or very little obviously. A friend of mine had a t3/t4 on his B16 but I can't remember if he had lag or not. Plus vtec made it hard to tell anyway I'm sure. Hope to come across a GT25 soon.
XBL: Jeemee Ghost
If I can get away without detonation and being lean, which I think is feasible, I think I'll be fine. I'm here to gain knowledge though so I'm open to suggestions. I may go with a TMIC, depending if I can find one designed to my likings.
#9 | |
The T3/T4 will create way too much lag at low boost; it's just not the right choice for your intended application.
Real world experience is what makes it good or bad. I am pointing out two cases where it worked fine. Do you have a real-world case where a Yaris (or other 1.5L) failed from running a low-boost application without management?
Your sarcasm does not contribute to the discussion -- your real experiences do!
#11 | |
this is a returnless fuel system buddy ;) buy a wideband, put in some larger injectors, and go to town. the car will take care of timing at 7psi.
jeemee, want to buy my charge pipe/intercooler? you'll need a shorter battery however.
#13 | |
Bathroom + Laptop = <3
Strangers, waiting Up and down the boulevard!!!! Their shadows Searching in the nighttttt |
#14 | |
XBL: Jeemee Ghost
XBL: Jeemee Ghost
Tamago, I'd like to see some pictures. Definitely interested.
#16 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
You don't need a built motor and tones of mods to put a turbo on your car. Id look forward to blowing up my motor so i could just rebuilt it stronger and go again. I'd say go for it and turbo the stock motor with 7psi. Don't let The Spectacle discourage anyone.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
My objections aren't about boosting a stock motor, its about boosting any motor without the proper supporting modifications of which the primary, and most crucial component is engine management.
Wait...what?
What? There's so much wrong here I don't even know where to begin.
| Small cars stacked up at dealerships. | freeridelectric | New YARIS Purchase Forum | 11 | 04-24-2009 08:23 AM |
| Small car's name? | yaris-me | Off-topic / Other Cars / Everything else Discussions | 13 | 03-29-2009 02:43 PM |
| Small science fiction story I wrote which includes the Yaris. :) | john21031 | Off-topic / Other Cars / Everything else Discussions | 3 | 11-21-2008 12:57 PM |
| How Small Would You Go? | Nigal | General Yaris / Vitz Discussion | 26 | 06-15-2007 08:44 PM |
| small 4ch amp. 4x100rms | ben dover | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 04-08-2007 04:17 PM |
