Old 06-07-2009, 04:45 PM   #1
Really COOL. What about the pressure sensor that is inside the passenger seat? You can't take the seat out without disconnecting that.
Old 06-07-2009, 05:55 PM   #2
jm350
jm350's Avatar
Drives: yaris 2007
Well, in my Yaris (2007 CE) there's no sensor inside the seat,
just those four sensors. These ones are "pressure" sensors, like i explained in the begining of that post.
It controls the explosion of the airbag, depending of the weight of the passenger.
jm350 is offline   Reply With Quote
Old 06-08-2009, 12:20 PM   #3
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Fantastic fabrication skills! There has to be an easier way!
The only sensor I am concerned about is the pressure sensor which will activate the airbag. The other one is the seatbelt sensor. Either find a resistor to bypass this one or disconnect the alarm.
If we put our heads together we can do it!
BTW - those seats look fantastic - where did you get them???
fuji is offline   Reply With Quote
Old 06-08-2009, 07:12 PM   #4
jm350
jm350's Avatar
Drives: yaris 2007
Originally Posted by fuji View Post
.....The only sensor I am concerned about is the pressure sensor which will activate the airbag. The other one is the seatbelt sensor......
Like i try to explain.....
There's 4 pressure sensors who control the airbag !!
Those 4 sensors are connected to a box called ECU and that ECU is connected to the airbag. So that assembly of four sensor control the airbag in combination with the seat belt sensor.
But during the modification you can disconnect the seat belt sensor but not the pressure ones.
And for me i thing there's no other way, you have to keep these sensors and make them fonctional.
