Old 06-07-2009, 05:22 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
put in my 1zz injectors yesterday. no CEL, runs great. my AFR at WOT during open loop before the 1zz injectors was about 12.4-5 now it's 11.4-5. *I was getting the 12.4-5 without the 1zz injectors because I switched back to my Stock airbox instead of my aFe intake that i had. When I was running with the stock injectors and afe intake, i had a 13.4-5 AFR @ WOT during open loop.
But now I am running the 1zz injectors and switched back to my aFe intake, and now am running the 11.4-5 AFR @ WOT openloop.
Old 08-24-2015, 11:26 AM   #2
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 Type S
Send a message via AIM to AzianCuz
Question 1ZZ Fuel Injectors
So I went ahead and ordered these, per the post:
Hopefully my lean code goes away? You guys have any other solutions for this lean code P0171?
BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
AzianCuz is offline   Reply With Quote
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
