Old 06-08-2009, 09:54 AM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
Originally Posted by scape View Post
out of curiousity, does having wider rims upfront change the handling any?
that probably depends on who you ask. If you want to get super technical, then yeah, it probably has a MINOR influence on how the car drives. In reality, it is probably so small, you cant detect it. The reason i have seen offset wheels on a FWD car was to run a WIDER front tire usually (like a 205 or 225 Front, and a 195 Rear tire; in fact the very first type R's ran this set up alot in Japan.) So you can do that, and make up for it in spring rate, damper settings, so on.
So why did i do? Because i am a cheap bastard. I got the wheels from a friend for free (i'm actually still "borrowing" them.) They are super light for stock wheels, and they look factory, like it is a Yaris-R model or something, and i like that.
The tire size is the same on the front and rear, and so the influence that wheel width has on handling is gone. So it will drive the exact same if i had the same size around or not. So basically, i am running two sizes for no other reason than that these wheels were free to me. You can't even tell by driving it, or looking at it. These are great wheels, i have thought about finding another set actually. I was going to use the wider ones for track tires (15x6.5), and the smaller ones (15x6) for street tires.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-08-2009, 09:55 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
keep an eye out for the 16's ! remember in 2003 toyota went to a 16X6.5 iirc for the rear
Old 06-08-2009, 09:59 AM   #3
kngrsll
Apexing Egg!!
kngrsll's Avatar
i think they would look really good for a street wheel. they weigh so little too!
Old 06-08-2009, 11:05 AM   #4
Morgan
Morgan's Avatar
Drives: 07 MM LB
2nd gen spyders have the 15/16 stagger
Old 06-08-2009, 11:07 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
ah, so 2002 :) my mistake
Old 06-08-2009, 11:11 AM   #6
Morgan
Morgan's Avatar
Drives: 07 MM LB
and for the record they do fit staggered on a yaris with 205/40
Old 06-08-2009, 11:21 AM   #7
kngrsll
Apexing Egg!!
kngrsll's Avatar
pics? they look great on my car, curious to see them. i think the way to go is get two sets, and split them for duty, track/street with some bolt on spacers.
Old 06-10-2009, 09:00 PM   #8
merryandlovely
Drives: Toyota
I think they would look really good for a street wheel. There weight so little too!
merryandlovely is offline   Reply With Quote
Weight Reductions scape General Yaris / Vitz Discussion 34 06-08-2009 02:31 PM
stock wheel weight? whiteghetto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-06-2009 08:00 PM
Wheel weight AlphaFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 09-04-2007 03:31 PM
weight on rs 15 inch wheel. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-04-2007 11:20 AM
