![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
You make a good point. I remember when most compact pickups had inline fours w/carburetors. They were notoriously gutless loaded or unloaded. My '81 Datsun King Cab seemed to be staining most of the time at highway speeds.
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
No need to shut up, good post. It's true, 2-door models have the easiest front seat access with the bigger doors. It's sad that automakers are starting to abandon them. The new 2012 Yaris will apparently NOT come as a 3-door option. Oddly enough, it was the only option in the US for its first two years. Even now, I would say at least half of all liftbacks sold since the 5-door came out have been 3- doors. You mentioned Yaris, Accent, Cobalt, & Focus were your only options fitting this criteria. Guess what, they all cease to exist this year. The Cruze sedan, '12 Accent, '12 Yaris, and '12 Focus hatchbacks will only be available as 5-doors. Looks like you'll be keeping your Yaris for a while.
We dumped C.R.. Were long time readers . Same old cr*p . Over and over and ....
![]() ![]() Drives: 07 lb jeep tj Join Date: Oct 2010
My only complaint with the yaris is I wish the shifter and center console was higher up, I feel like I'm reaching for the shifter and it would also be nice if it was made from a little better plastic. Other than that what can you excpect for a 12k car? I think in about 10 years the yaris will have the following like the civic hatchback and the value's will stay pretty strong.
If the fit was the same price as the yaris I would have picked the fit hands down I think it is that much nicer of a car but its not worth the extra price for me I needed a point a to b car and the yaris does that best. |
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
I'll add that I'm not a fan of the electronic fuel gauge. I can never tell if it's blinking slow or fast. Some things should just be analog. Like a watch. I can't tell time on a digital watch
#8 | |
It's 12:40 right now. "Twelve Forty". Numbers are kind of an important part of life.
No, to me it's 20 till 1:00.
My problem with the digital gas gauge bars is that they jump instead of flow. Say you get to 1/2 tank and the gauge is exactly correct and shows you 4 bars out of 8. Then you drive 50 miles and there are still 4 bars. You can't still have 1/2 a tank. I want to see what's between 1/2 a tank and 3/8 of a tank.
As to telling time on a digital watch, I was being a little funny . The truth is that I prefer using an analog watch for the same reason. I don't want to see minutes jump from one to the next I want to see them flow from one to the next. Just my preference as there were no digital watches until I was older (or calculators, I used a slide rule).But I do look at my watch at 12:40 and think 20 of. |
147K-Blue / 24K-Yellow
Drives: 2010 Ylw 3dr. AT(Blue-Wife's) Join Date: Mar 2011
Rick,
I wish the car had a whole set of Analog gauges Tach, and oil pressure...but thats the motorhead of me coming out....Digital?...I like water temp to be digital! Another car I considered, and forgot to mention in my first post was the Golf TDi, but the so called better mileage (with more expensive fuel) doesn't justify their ungodly high price $24,000+ not to mention that there is more maintenance to do on a VW TurboDiesel!
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires. Repair List: 1 new blower motor, making funny noise. @ 91K (Water pump @ 120K) Mod List: 1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott) |
I have an analog tach. We both drive 2010's and I don't have the power package. Maybe you get the tach with the manual transmission.
And speaking of slow, I once had a 62 VW bus.
#13 | |
The early 80's diesel Bus was slow also, I followed one for about 10 miles several years ago, he pulled into a gas station..and the gear head part of me had to follow and ask...Was that factory? he showed the whole deal and yes it came that way, and I looked it up when I got home, I think it had something like 50HP! Not a popular option?
#14 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Correction - I was making up a list of cars I owned and realized that it was a 1968 bus. Also had a 1978 bus.
Back on topic
I wish CR would do base model cars and trucks only. They always test the fully loaded or fully equipped models. I think a better comparison would be with the base models, to show what is offered at that price and trim level.
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
Hello. Been lurking in this forum for over a month and have spent HOURS researching. Some great people here. First off let me start by saying I purchased a 3 dr LB w/ Power Package in Polar White a few weeks back. And of course it is a manual :)
Let me explain my purchase. I have wanted a Yaris for several yrs now, however, until recently you had to pay an arm and a 2 legs for the safety items I wanted, minus stability control. So I settled for the 1st generation 2008 Honda Fit Sport. The looks were not great but it was a good lil car. So then the 2nd generation Fit came out in 2009 and I purchased a top of the line model. Unfortunately I was also forced to purchase the $1,800 navi to get VSC :( The car was just under 20k loaded with every feature. I still wanted the Yaris but it did not have 6 air bags, VSC so I went with the Fit, aesthetics aside. I drove this Fit for 2 yrs w/ several minor probs all fixed under warranty. Probs included squeaky pedal(minor) to more major issues such as the drivers window CONSTANTLY, slowly edging down, requiring me to pull it up and dificulty (grinding actually) while putting it in 5th gear. I've driven a manual my entire life(since 14, and 35 now) so I know it wasn't me. The dealership was fantastic with the pedal squeak but could never fix the other 2 probs. I also forgot to mention the VERY inaccurate computer mpg guage!! I spoke to a 19 yr Honda mechanic and he also explained he was not AT ALL happy with the build quality of the 2nd generation Honda,especially for it's price and for being a Honda. SO, unhappy with the Fit I moved into a 2011 LOADED Honda Element. Problems from day two on the Element. Problems with difficulty starting(garaged all winter) to buttons on cruise control not working. So I went to visit my sister near KC Missouri and stopped at Toyota dealer after reviewing their new inventory of Yaris's fitting my criteria. I was sooooooooo happy that Toyota finally added ABS,6 air bags, and VSC STANDARD!!! Traded in the Element, lost $2,500, or my ass, however you want to look at it. BUT I finally got what I wanted and to be honest their is NO comparison between a Honda and a Toyota in build. EVERYTHING on the Yaris is tighter and more solid than the 2nd generation Fit I had. The door shuts more soundly. The ONLY thing "better" on the Fit was the pretty dash and the cushier materials and the "magic seats." The ride of the Yaris is just as good, the seats feel great(I'm only 5'7" but I've traveled in them in 14 hr increments) and EVERYTHING feels more solid. Honda might have spent the extra money($4,700 more in my case) on a fancier interior but I would take the Yaris over the Fit anydamn day of the week. AND I'VE OWNED TWO!! I feel like a pig in shit and have a great Yaris that does everything I want it to. I considered waiting for the Scion IQ(Toyota IQ) coming late summer, but it is smaller and I don't need to pay 4k more like I did for the Fit for a fancier interior. So if any of you out there in this forum feel like you should have bought a new Fit, I'm here to tell you you made the right decision. I know I won't be stranded on the side of the road with the Yaris and I couldn't have made a better decision. Consumer Reports is soooooooo wrong about this car-the Yaris. |
#18 | |
Sorry you had to dump so much money switching 4 vehicles. I can almost guarantee you that you'll have no problems for a long time with the Yaris. Mine hasn't been to the dealer for any issues yet with 105,000 miles. Another member here drove 425,000 miles as a courier with only one minor repair. Truly remarkable quality and reliability. Enjoy!
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Yaris & Consumer Reports | bobby | General Yaris / Vitz Discussion | 57 | 01-31-2009 11:17 AM |
| Consumer Reports | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 28 | 04-29-2007 01:13 PM |
| Consumer Reports Best & Worst 2007 Cars | Bretsuaz | General Yaris / Vitz Discussion | 23 | 03-15-2007 05:51 PM |
| Consumer Reports on Ethanol | Driver | General Yaris / Vitz Discussion | 6 | 09-01-2006 11:21 AM |
