Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
My .02
Good discussion here.
I used to get caught up in what an oils basestock was comprised of and was a bit of a PAO snob-if it wasn't 100% group IV or V it wasn't worthy of consideration. Now I am of the opinion the only thing that matters is how an oil performs in YOUR application under YOUR operating conditions. I use used oil analysis as a guide. The whole true synthetic thing is a little dated. The lines between syn and dino are so blurred now that it's pretty much just a marketing tool. Even "regular dino oil" is SO much better than the oil just 10 or 15 years ago. Now I pay little attention to what an oil is currently formulated with in terms of basestock and pay more attention to performance and the actual cost of use. By the way the Amsoil XL line was pretty much designed for the quick change market and those who wanted an API certified oil for warranty reasons-it is group III (which Amsoil has made no secret about, BTW) and it is an excellent performing product. Amsoils higher end oils are formulated for longer drains and they put the money into performance rather than submitting for API approvals testing. Which oil you choose will probably come down to how long you are comfortable extending oil change intervals and if you are still under warranty and are comfortable going against Toyota's recommendations or not. The XL meets all the warranty requirements if changed according to Toyota's recommendations. As I have mentioned in a previous post I think Amsoils 0W-20 is one of the best long drain oils available-period. I recently ran it in a Crown Vic Police Interceptor with 15.5 thousand miles AND over 300 hrs of idle time and it could have gone longer! I change oil for a friend who has run Amsoil in two GM V-6 cars with 25 k drain intervals. He traded the 1st with over 200k on the clock and it was still going strong. He used to add on average 1.5 qts of make up oil in 25k. His current car (Monte Carlo, 3.4 L) has 100k and uses no noticeable oil in 25k. The Mobil 1 and Pennzoil Platinum products are excellent also and the Platinum really stands out as an excellent value when purchased at Wal-Mart by the 5 qt jug. (Current price last I knew locally was $20.) I've heard any variety of reports of these being PAO, grp III or any combination of the two. In all honesty I think there is more than one way to skin a cat. Probably any API certified SM rated oil at Toyota's recommended 5k/6 mo. intervals will take these engines further than most of us care to go. It comes down to how you use your car, how often you want to change you oil, your operating environment, warranty concerns, how long you plan to keep the vehicle, what oil YOU like to use, etc. If I'm not mistaken the infamous 300+k Yaris used Wal-Mart Super Tech Syn 5W-30 which I'm quite sure is Grp III (Warren). Not bad for 3 buck a quart oil! I pretty much stick to Amsoil and Schaeffer's products these days. I'm going to change out my factory fill at 1k and I'll be using Schaeffer's Supreme 7000 5w-20 and Nippon filters (TheSilkySmooth's Denso horror stories have me running scared, lol) I'll be sticking to Toyota's 5k/6 mo plan during the warranty period. I'll still do oil analysis though! BTW it's perfectly safe to switch to synthetic any time one wants. Many cars come from the factory with syns in the crankcase and an engine will break in just fine with synthetics. I like to keep the first interval or two a little shorter while an engine is breaking in which can be a little costlier with syns, but what the heck if it helps one sleep at night? Another point I should bring up is the fact that an oil's color really has no bearing on whether it is suitable for continued use or not. I recently changed the oil (7.5 gallons capacity) on a Caterpillar 3126 diesel engine and less than 10 operating hrs later the oil was so dark I couldn't see through to the dipstick any more. Should I dump the 7.5 gallons of oil every 10 hrs? To the opposite extreme you may have almost perfectly clear oil with 10% fuel dilution that is no longer suitable for use. The color of an oil as a maintenance tool is limited at best. During it's service life oil suspends extremely small particles of soot, carbon etc that are too small to be captured by the filter and they can darken the oil. Oils are designed to hold these extremely small particles in suspension and keep them from agglomerating so they don't form deposits or cause accelerated engine wear. Having said that who doesn't like to see nice clean oil on a dipstick? If it makes you feel better and it's not cost prohibitive, change it! BTW, in light of the TSB Toyota released approving the use of 5W-20 oils in the 1NZ-FE engine I was wondering how many people are using the 20 wt vs the 30? There is another interesting debate in itself! Hey Yaris Hilton, which weight of oil are you running? Do you favor a particular brand? Just curious! Thanks all for the discussion! R2 Last edited by R2D2; 06-09-2009 at 01:05 AM. Reason: spelling |
Half a Bubble Off Plumb
Right now the 2009s have what they came from the factory with. The 2007's got 5W-30 Castrol GTX in it. I'd be happy with any of the current API certified SM or ILSAC GF-4 oils. I used to run 10W-30 Pennzoil in the 2001 Echo. It was conveniently available, and very cold starts aren't an issue here.
![]() ![]() ![]() Drives: Blazing Blue 08 liftback Join Date: Dec 2008
I got some info from the technical folk at Amsoil to help clarify for all of us. As I said previously use what you are comfortable using.
From the Techs and the Amsoil Web; "Q: Does AMSOIL utilize PAO, Group IV technology, and if so, what products carry these credentials?" "A: The Technical Department is not privy to what base-stocks are used in specific products. However, we can tell you that we do utilize the best synthetic base-stocks, including group IV, in our formulations." "A: As the developer of the world's first API qualified synthetic motor oil in 1972, AMSOIL has gained more experience than any other oil company in formulating automotive synthetic lubricants. It is this extensive experience that provides the ability to maximize product performance through use of a full range of high-performance synthetic base oils, most notably polyalphaolefin (PAO). AMSOIL views synthetic base oils the same as it views additives, with each having its own set of unique properties. AMSOIL engineers its lubricants with the synthetic base oil or combination of base oils best suited to a specific lubricant’s application demands (gasoline, diesel, racing, transmission, gear, extended drain, extreme temperature, etc.)." "AMSOIL INC. maintains an unwavering commitment to provide products that outperform the competition and deliver maximum benefits to all AMSOIL customers. Performance is the bottom line." About API and XL series oil; "A.P.I. stands for American Petroleum Institute, Petroleum being the key word here. AMSOIL products are 100% synthetic, which the word synthetic is not part of the API classification. The XL oils are a 100% synthetic not a blend." Sounds like some of you have been working on cars of many types for many years. Between all the posts I have learned more about the concerns and uses of synthetics. Amsoil provides synthetic products for other applications . Diesel oils, transmission fluids, brake fluids, greases, radiator fluids(250,000/7 year) etc... If you have a particular Amsoil question you can e-mail me at Greg@TruLube.com or send a PM. Please visit TruLube.com to get information regarding the latest Amsoil products.
#4 | |
And Amsoil gets its synthetic stock from Exxon/Mobil, and Mobil, along with most others have the API approval on all of their products, even their synthetic oils...even bargain synthetics like Phillips/Conoco (supplier for Ford, group IV, btw) ...guess they're not waiting around for the founding of the American Synthetic Institute
Crazy Oil Sniffer
Thanks, Yaris!
I agree the SM "conventional" oils are all so good now it's really splitting hairs between brands. GF-5 is supposed to be even better, right around the corner. I'm going to start out with a 5W-20 since it is approved, and if evreything looks ok I'll stick with it. |
The GF-5 site now says the specification's expected to be finalized in the third or fourth quarter of 2010. May be a bit past that till we see oils with that spec on their label.
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| embarrassingly bad mileage... REALLY | XYaris | Fuel Economy Forum | 83 | 05-05-2009 04:47 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
| When to switch to synthetic oil? | jay | DIY / Maintenance / Service | 65 | 02-15-2007 08:44 PM |
