Originally Posted by largeorangefont
You will need more than the useless rear shock bushing brace if you go with a coilover setup on the rear shocks.
you could groove the rear shocks and run compression rings for coilover sleeves. That is what I run on my Cobra in the rear.
With a stiff rear sway bar and coilovers you could punch right through the upper shockmount. You would at least need delrin upper bushings and possibly weld or bolt on a steel plate for reinforcement.
do you have a link for this process? If not, could you explain more about grooving the shocks?
My idea is similar i think, i thought about simply welding on a collar to set the spring perch on.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
