Old 06-09-2009, 07:13 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by kngrsll View Post
do you have a link for this process? If not, could you explain more about grooving the shocks?
My idea is similar i think, i thought about simply welding on a collar to set the spring perch on.
i can groove them at my shop :)
however, Gordon at koni does not recommend doing this, as the outer shell of most shocks is not thick enough to withstand grooving/welding unless already equipped in such a way.
Old 06-09-2009, 07:17 PM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
really? shit... what about a sleeve with the top filled in and a hole drilled into the top for the shaft. So the sleeve fits down over the shock, and the top (rim?) of the collar goes over the top of the shock where the shaft passes through the hole. Then, you can have another collar on the bottom of it where you can slide a perch onto it.
Does that make sense at all?
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-09-2009, 07:19 PM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Shocks are not designed to be load bearing suspension components usually, so that probably would not really work either. If the shock was beefy enough to do that, you could groove it anyway.
Old 06-09-2009, 07:17 PM   #4
largeorangefont
Break'em off some.
Agreed. You woudl need to check with the shock manufacturer to see if this is even viable.
It is an easy process to groove the shock bodies though.
June 13th Shannonville Full Track lapping event! Touge.ca Canada 0 06-04-2009 06:48 AM
June 21st Cayuga TMP track lapping event, 2009-6th Touge.ca Touge.ca Canada 0 06-04-2009 06:47 AM
New photos of my Yari with my new suspension - coilovers (track) Trish Photo-Video-Media Gallery 35 05-25-2009 12:56 AM
2009 Track lapping events, Touge Motorsports, www.Touge.ca. Touge.ca Canada 3 04-26-2009 04:49 AM
Yes, I can finally post here! (Confessions of a track newbie) cleong Tracking, Racing, Auto-X Forum 12 10-20-2008 11:43 AM
