#19 |
I'll take pics of the Silk Roads on my car.
#20 |
Break'em off some.
You will need more than the useless rear shock bushing brace if you go with a coilover setup on the rear shocks.
you could groove the rear shocks and run compression rings for coilover sleeves. That is what I run on my Cobra in the rear. With a stiff rear sway bar and coilovers you could punch right through the upper shockmount. You would at least need delrin upper bushings and possibly weld or bolt on a steel plate for reinforcement. |
#21 | |
eye-to-eye shocks can be modified to accept spring perches :) if my Ksport perches don't work out that'll be my next step.
#22 |
Break'em off some.
#23 | |
What?
#24 | |
Apexing Egg!!
My idea is similar i think, i thought about simply welding on a collar to set the spring perch on.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#25 | |
Apexing Egg!!
#26 | |
http://www.jegs.com/i/Koni/610/8216-2027/10002/-1
#27 | |
however, Gordon at koni does not recommend doing this, as the outer shell of most shocks is not thick enough to withstand grooving/welding unless already equipped in such a way.
#28 | |
Break'em off some.
Pages 4-7 deal with the grooved shock body and the spirolock ring that hold on the coilover sleeve. http://www.maximummotorsports.com/co...p/MMCO-4r6.pdf |
#29 | |
Apexing Egg!!
Does that make sense at all?
#30 | |
Break'em off some.
It is an easy process to groove the shock bodies though. |
#31 | |
Apexing Egg!!
i like that idea alot...
#32 | |
Break'em off some.
#33 | |
Break'em off some.
Yea.. the shock mount might need to be boxed in completely. If I was going this route, that is what I would do. |
#34 |
Apexing Egg!!
what do you guys think of using these? you can select rate, but probably cant adjust height though. I think i measured the rear spring to be 5 1/2" in diameter.
http://www.dansracingsupply.com/AFCO.htm http://www.afabcorp.com/AFCO_Dynatec...t_Conventional So if you can figure out what spring will allow you to have a decent height, and then you can get collars for the front, you are good to go. you wont have rear height adjustability, but you could use a good strong rate.
#35 |
Gordon at koni said 9" would be good for my setup, and i'd imagine that a 9" travel shock would work for y'all in the back as well
#36 |
Apexing Egg!!
got any aftermarket springs around you can measure?
| June 13th Shannonville Full Track lapping event! | Touge.ca | Canada | 0 | 06-04-2009 06:48 AM |
| June 21st Cayuga TMP track lapping event, 2009-6th Touge.ca | Touge.ca | Canada | 0 | 06-04-2009 06:47 AM |
| New photos of my Yari with my new suspension - coilovers (track) | Trish | Photo-Video-Media Gallery | 35 | 05-25-2009 12:56 AM |
| 2009 Track lapping events, Touge Motorsports, www.Touge.ca. | Touge.ca | Canada | 3 | 04-26-2009 04:49 AM |
| Yes, I can finally post here! (Confessions of a track newbie) | cleong | Tracking, Racing, Auto-X Forum | 12 | 10-20-2008 11:43 AM |
