Old 06-10-2009, 12:22 AM   #1
MGargano
Drives: 2009 Yaris Hatchback
[QUOTE=Tamago;332994]throw in a bit of extra rear "negative" offset and you feel those fenderwells nicely! /QUOTE]
I was with you until this point. Do you mean I should use the hub spacers in the rear?
MGargano is offline   Reply With Quote
Old 06-10-2009, 12:27 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
[QUOTE=MGargano;332997]
yes, hub spacers help when you buy wheels that fit well up front but look a little sunken in at the back. the cars pictured are 10mm spacer on the left car and 13mm on the right car (but offsets are much lower than most yaris owners suggest, 15X8 +20mm on the left and 15X7 +30 on the right)
i hope we can talk you into some nice wide 15's :)
Old 06-10-2009, 12:35 AM   #3
MGargano
[QUOTE=Tamago;333000]
I suppose one advantage of going with 15's is cheaper tires and wheels due to smaller size? Any other advantages?
Nike Comp...I LOST. WindUpToy Off-topic / Other Cars / Everything else Discussions 9 04-18-2009 03:01 AM
lost under car seat, i cant get it out! blakxhart DIY / Maintenance / Service 14 02-23-2009 06:19 AM
8/9/08 Appleton Wisconsin - Lost Pictures kuyachris84 Great Lakes 1 11-11-2008 01:32 PM
Lost a Hub Cap, should I go all steelies? mgthompson Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 04-04-2007 10:25 AM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
