Old 06-10-2009, 12:23 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by mrbond View Post
a 13whp gain over stock is not bad for five bolt-ons.
sounds like a fat dyno to me... plus the guy didn't even bother grabbing a crank signal.. mph dyno graphs blow.
Old 06-10-2009, 12:28 PM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
he did do it i just forgot to put it in rpm. Just match it with the others it is a mirror basically. Every dyno is diff usually with this low whp you can expect a +/-2 variance. it could be fat or the others could just be stingy
Yoda is offline   Reply With Quote
Old 06-10-2009, 12:30 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
agreed. and this is why you should always return to the same dyno for every new pull :)
Old 06-10-2009, 12:32 PM   #4
Yoda
Yoda's Avatar
i did everything was done the same. and as a plus it is hotter now since its summer.
Old 06-10-2009, 08:51 PM   #5
merryandlovely
Drives: Toyota
That graph shows a lot more than 3 WHP increase. You sure you you are reading it right
merryandlovely is offline   Reply With Quote
Old 06-10-2009, 10:13 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
those curves aren't before and after lol.. you sure YOU're reading it right?
My DynaPack Dyno Results. PETERPOOP Performance Modifications 63 03-10-2009 06:02 AM
TS/Xd Long Tube Header & Intake dyno results richardholdener Yaris TS Talk 21 01-06-2009 05:28 AM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 05:27 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
