Old 06-11-2009, 02:35 PM   #1
Morgan
Morgan's Avatar
Drives: 07 MM LB
Originally Posted by The Spectacle View Post
- Running meth is a great fix to reduce your knocking motor in boost. In fact, its pretty much all you need if you're knocking
"Knock" is a process where fuel combustion happens prior to ignition and is temperature and pressure based so by reducing ignition temps (water) and/or reducing the chances of preignition (methanol/higher octane fuel) it can indeed solve many minor to moderate knock issues. In addition to the yaris' keen ability to pull/retard timing at the drop of a hat, knock is almost inevitable in any FI application for this car, addressing it with water/meth and higher octane fuel is par for the course..... As noted in several threads in the FI forum, kthnxbyi
just to clarify if I used too many big words
please respect the hard work and dedication of the members who have tried and tested many different methods with the 1nz before posting like you know more than, what was it "98%" of us?
Old 06-11-2009, 02:43 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
Small cars stacked up at dealerships. freeridelectric New YARIS Purchase Forum 11 04-24-2009 08:23 AM
Small car's name? yaris-me Off-topic / Other Cars / Everything else Discussions 13 03-29-2009 02:43 PM
Small science fiction story I wrote which includes the Yaris. :) john21031 Off-topic / Other Cars / Everything else Discussions 3 11-21-2008 12:57 PM
How Small Would You Go? Nigal General Yaris / Vitz Discussion 26 06-15-2007 08:44 PM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 04:17 PM
