Old 06-15-2009, 11:42 AM   #1
1stToyota
1stToyota's Avatar
Snake oil implies that it's not a good product. Synthetic might not be needed in most makes, but testing often shows that it's a superior product. Hershey chocolate will do the job just fine, but I'd much prefer to pay the extra to get the better Dove dark.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 06-15-2009, 12:04 PM   #2
bronsin
bronsin's Avatar
Synthetic oil was delveoped for use in jet (gas turbine) engines where operating temperatures exceed 400 degrees F. Since internal combustion engine temperatures are less than 200 degrees F synthetic oil is not needed. Marketing types saw the need people have for "something better" than the next guy and started the hype.
Old 06-15-2009, 12:21 PM   #3
1stToyota
1stToyota's Avatar
If it's not needed in cars, just jets, a UOA result will be no better than dino, always, because it's just hype and an overkill to use synthetic...or it does provides better protection and will almost win in a UAO showdown...
2008 Scion xD
Old 06-17-2009, 04:05 PM   #4
SilverGlow
Drives: 2007 Yaris Hatchback
You are forgetting one fact:
Synthetic will allow you to go LONGER between oil changes then conventional, and that is reason alone to use it. It can also provide 1% to 2% higher MPG too.
SilverGlow is offline   Reply With Quote
Old 06-18-2009, 08:33 AM   #5
1stToyota
1stToyota's Avatar
I use it because there's the chance that it's a superior, not an inferior product, period. And while I'm depending on Toyota to cover any warranty issues I'll follow the 5k OCI, no matter what oil I use.
2008 Scion xD
Old 06-15-2009, 12:20 PM   #6
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Hersheys is fine chocolate! Much better than that fake Dove crap! hehe Just kidding! Seriously though, Hersheys is very good chocolate and so is Dove! Synthetic is good oil and so are some conventional oils. Castrol GTX for example is great conventional oil. The additives are what makes it good. Turbo's with super high heat will cook conventional oils and turn them to "coke". Turbo's pretty much require synthetic, if only to help you sleep at night. Some folks are reporting MPG gains after switching to synthetic.
Snake Oil it is not.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 06-20-2009, 07:17 PM   #7
TheSilkySmooth
TheSilkySmooth's Avatar
Recently Ive seen that Castrol GTX has one of the WEAKER additive packages. Mobil Clean 5000 and Formula Shell are two of the better conventionals, GTX is down the list. Look at VOA and UOA on BITOG for the facts. Formulas are changing all the time. Many users reported that Exxon-Mobil M-clean is better than M1 for normal interval OC.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
embarrassingly bad mileage... REALLY XYaris Fuel Economy Forum 83 05-05-2009 04:47 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 08:44 PM
