Old 06-15-2009, 12:04 PM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
-2.2 degrees front camber
0 toe
-1.5rear camber
0 toe
this is nearly what i run, i have a tiny bit of toe in the rear. tire wear is great.
Originally Posted by Loren View Post
Start with 2-2.5 degrees negative camber in front with zero toe or VERY slight toe-in (maybe 1/16"). Leave the rear alignment stock.
but this is probably easier to do :) I wonder how much influence the rear shims i have play on handling. When i did the full alignment, it sure make a huge difference when the car was completely stock.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
June 21st Cayuga TMP track lapping event, 2009-6th Touge.ca Touge.ca Canada 0 06-04-2009 06:47 AM
