#1 | |
Audio Junky
You can expect to see around 5-10MPG difference on average between the two speeds... especially if you don't try the "Hangtime" skill... Tho hangtime I think has been exaggerated, it does help. I don't think it really has anything to do with ECU maps or whatever, but rather physics of energy & torque required to speed up versus energy/torque required to maintain speed. There are some times I notice that going slower makes it harder to get good mpg's than slightly faster... for example... I find it easier to get good numbers going around 60mph than 55mph on the highway I use to go home. Regardless of of fast I go I seem to use the same throttle possition after I get up to speed and back off on the trottle a bit. So really, the slower speed, but same usage of gas means I get lower mpg at 55. That doesn't appear to be true on all roads/highways tho. Still haven't gotten to 45 yet. I lowered my tires back down to 40psi... so I don't know if i'll see it ever. 43's seem to be what I see. I had one 250+ mile trip that I got almost 48mpg on, But not for a full tank. |
#2 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
Half a Bubble Off Plumb
That's drafting.
Audio Junky
did I mention how close I was? As myth busters showed, you don't have to tailgate to get gains... When doing 70mph... even 50-100ft behind will give noticeable improvements in efficiency.
#6 | |
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
I usually get 43.6 average between my tanks, but the biggest factors for me was the city to highway ratio, and the fact that the engine was warmed up well as normal daily trips are just not long enough to warm up fully. Of course, I hypermilled big time to prove a friendly point to a Prius owner, allowing for 45-60 on hills and generally cruising at a mere 50 on relatively flat stretches. I was able to achieve all of that staying within the speed minimum/maximum ranges fairly easily. I don't think I could have gotten above 50 by just remaining at 60 the whole way, especially on the hills. I've yet to hear from someone tailgating a semis (which is dangerous anyway) achieve those same numbers, and doubt I ever will as they're still running their engine at higher RPMs. |
#7 | |
![]() ![]() ![]() Drives: 09 3Dr Manual Join Date: Jul 2009
Congrats on the 45 mpg! Last edited by 2+2; 09-28-2009 at 09:35 PM. |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Why is my new 09 Yaris MPG is so low | soup1207 | Fuel Economy Forum | 34 | 06-12-2009 03:45 PM |
| 52.60 mpg | Kaotic Lazagna | Fuel Economy Forum | 42 | 05-19-2009 01:45 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
