#37 | |
Synthetic oil was delveoped for use in jet (gas turbine) engines where operating temperatures exceed 400 degrees F. Since internal combustion engine temperatures are less than 200 degrees F synthetic oil is not needed. Marketing types saw the need people have for "something better" than the next guy and started the hype. |
#38 | |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Snake Oil it is not.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#39 | |
#40 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
I tried Valvoline Synthetic in my '08 Yaris for a month-it did not like it one bit. From a noticably noisier engine to a significant drop in my MPG (I always run in the 40's with it till I tried synthetic and it droped into the high 30's for the entire time the oil was in it). I went back to conventional valvoline after a month and suddenly the engine seemed more dampened in operating noise and my MPG went right back up to 43. This is only my experience with it and I've read a few others that noticed this same effect with their Yaris.
#41 | |
#42 |
I used factory fill, ENEOS semi-synthetic, Amsoil HP, now PP full synthetic, all 5w-30, and engine had a little bit less noise with each oil change.
#43 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
#44 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
I could not DISAGREE MORE. There are MANY true fully synthetic oils sold in the USA, and made in the USA. Don't you realized that even with the "inferior" US sold synthetics, your Yaris will still last 300,000+ miles? And there is nothing wrong with the Toyota filters for the Yaris. You constantly vomit wrong information. |
#45 | |
Synthetic will allow you to go LONGER between oil changes then conventional, and that is reason alone to use it. It can also provide 1% to 2% higher MPG too. |
#46 | |
I think your change in MPG is caused by some other reason. The difference in MPG between ANY oil brand is 2% or less. The increase in MPG when using the "best" synthetics is just 1% to 2% over ANY conventional. |
#47 |
toyota
sorry had to disagree... synthetic did not give me better mileage it actually dropped my mpg ..I use to get 580-590 average on 36 liters now im getting 540-560km...go figure .same driving habits same temperature..
![]() oh yah 5w-20 same as stock. unless you go for 0w-20 then mpg will definetely increase.. |
#48 |
After reading a few of the comments here I do indeed feel like my engine is actually quieter now that I've gone back to conventional oil.
I don't see any reason why my engine could'nt go 300k too.
#49 |
I use it because there's the chance that it's a superior, not an inferior product, period. And while I'm depending on Toyota to cover any warranty issues I'll follow the 5k OCI, no matter what oil I use.
#50 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
from the Valvoline website: MYTH: There is not any real difference between conventional and synthetic motor oil. REALITY: There are not any real differences in the basestocks used to make synthetic and conventional oils, but there are differences in the additives and process used to make the final products. Continuing: Castrol Syntec 5W-30 is not synthetic, Pennzoil Platinum 5w-30 is not synthetic. Royal Purple street oil is NOT synthetic. - Alternatively: Motul 300v is grpV synthetic, Total Quartz Future 9000 is Grp iv/v synthetic, Fuchs Silkoline is grp V synthetic. Redline is synthetic. Some Amsoil products are synthetic, but mainly group iv which is inferior PAO base. PAO is not a good lubricant, though its a good additisation carrier and works welll when blended with group V base stocks. Mobil1 4t racing is full synthetic and 9 bucks a quart. I'm not saying the USA sold "synthetics" are bad oils, just why pay the cost and not get the benefits of a REAL synthetic? You want a USA synthetic-beating oil for cheap, buy Rotella-T CJ4/Sm 10w-30. ABout 3 bucks a qt in gallon jugs. Too thick for a Yaris, IMO. Filters: The Toyota Denso Thailand filters have NEVER worked for me, across multiple trials and vehicles, and thats all that matters to me. I just want enthusiasts to be aware that I have encountered problems and this might help them solve their problem. The WIX #51396 have worked well and are recommended. As for vomiting incorrect info, I'll leave that to you. Last edited by TheSilkySmooth; 06-20-2009 at 07:09 PM. Reason: sp |
#51 | |
#52 |
Recently Ive seen that Castrol GTX has one of the WEAKER additive packages. Mobil Clean 5000 and Formula Shell are two of the better conventionals, GTX is down the list. Look at VOA and UOA on BITOG for the facts. Formulas are changing all the time. Many users reported that Exxon-Mobil M-clean is better than M1 for normal interval OC.
#53 |
der Zeck
AMSoil..... that is all I have to say
#54 |
╚══════════RN
Just did my second oil change today. I now have about 13K miles on the Yaris. I switched at about 4K miles -- just felt like it. I use Amsoil 5W-20, and change it every 7,500K miles.
Wow, my car didn't blow up and the earth didn't stop turning. To the OP, just do whatever you want.
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| embarrassingly bad mileage... REALLY | XYaris | Fuel Economy Forum | 83 | 05-05-2009 04:47 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
| When to switch to synthetic oil? | jay | DIY / Maintenance / Service | 65 | 02-15-2007 08:44 PM |
