Old 06-17-2009, 01:59 PM   #1
rbell
Drives: 2009 Yaris HB
2009 HB fog light installation
Ordered a set of fog lights from Micro Image. Is it really 10 pages of instructions to install these? I thought the '09 came "pre-wired". Removing the front bumper and the underside of the steering column?
rbell is offline   Reply With Quote
Old 06-17-2009, 07:35 PM   #2
The pre-wiring saves you from having to pull a wire through the firewall and lets you use the stock fuse slot and relay slot. To mount them you still have a little bit of labor (and wiring) to do.
Old 06-17-2009, 08:01 PM   #3
rbell
Thanks. I'm capable of the installation. I just remember when I used to drive Dodge vehicles, the cars were actually pre-wired. If you pulled the fog light cover off, there was a connector right there. The harness was already in. Same with the radio. If the car didin't have one, the harnes was still behind the plastic plate. It was literall plug n play. Seems like the cars today would already be wired for options, just to keep the manufacturing process consistant.
Old 06-17-2009, 10:16 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
If your talking about the factory PDF , it shows you how to remove body
parts to install the lights , and where and how to plug everything in .
So unless you know what you are doing then yes they are inportant .
unless you have done it before, then you will know all the short cut's
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 06:15 PM
Question about Yaris 2009 fog light? JAyala Cosmetic Modifications (Exterior/Interior) 0 02-07-2009 04:51 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 09:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
