Old 06-20-2009, 10:35 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by kngrsll View Post
i was thinking, i could almost even get away with the front sway bar upgrade instead since im running such high rear rates.
that's a band-aid and will slow you down as it will lift the inside tire causing wheelspin :(
Old 06-21-2009, 08:57 AM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
yeah, i think i agree... I think i need some sleeves and springs really. but if i do that, i want stiffer rear springs. i think my ideal set up would be 300 lbs F, 400 lb R. Im considering the perch on the rear shock idea. Would you do it if i sent them down?
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-21-2009, 10:28 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
perch on the rear shock isn't recommended. the wall thickness is not thick enough i think. maybe look into shocks from teh rear of an accord?
