Old 06-20-2009, 10:48 PM   #1
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Originally Posted by firebob View Post
Ok sure.
But both hoses do not do the same thing.
The set up is to pull in air form before the throttle body through the crankcase and dump it back into the intake. The hose that dumps back into the intake has the check valve. When you let off the gas the throttle body closes down most of the way and the motor would suck air though the crank case and burn off the fumes in the crank case.
But with only one you will only get blow by and a bit of air from the change in the temp as the car heats up and cools down out of that hose. I didn’t see that you had removed the other hose.
I'm confused. The hose from the PCV goes to the intake manifold after the throttle body and there is another hose that goes after the MAF. What is the point in having two? After throttle shut down wouldn't it just circulate air through the hose to the manifold?
Old 06-20-2009, 11:20 PM   #2
vacuum sucks, simple as that. There is a difference in pressure on the ends of each hose, so the PCV system works as a kind of restricted bypass
Old 06-20-2009, 11:43 PM   #3
firebob
Drives: 09 yaris
There are 2 hoses.
#1 goes form the PCV valve that is screwed into the crank case to the intake.
#2 goes form the air intake to the crank case.
In the red box is #1. The black fitting is the PCV valve.
In the green box is where #2 should be. With a stock car this would only see clean air.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 06-20-2009, 11:47 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
There are 2 hoses.
where did you get this information FORM?
Old 06-21-2009, 12:00 AM   #5
firebob
Drives: 09 yaris
I guess I can’t spell after 11:30 at night after being up all day and drinking a few.
Old 06-22-2009, 11:19 AM   #6
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
There are 2 hoses.
so does this mean we only need one filter which is on the red box.
$30 Oil Catch Can, DIY Ogredude DIY / Maintenance / Service 79 05-13-2011 11:05 AM
perrin oil catch can staypuft Performance Modifications 3 11-16-2008 12:20 AM
OIL CATCH TANK increase performance? 33lam Performance Modifications 29 11-11-2008 01:08 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
