Old 06-22-2009, 01:02 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
psi drop where? where is the psi drop?
its says so on that specific filter when i went to homedepot/canadiantire to check it out right on the filter itself says it will have " 5 PSI " drop by using it.
Old 06-22-2009, 01:06 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
5psi drop at what air flow?
Old 06-22-2009, 01:08 PM   #3
marcus
toyota
marcus's Avatar
the excess air coming from the engine thats being recycled back to the intake. that air is whats being filtered due to oil that goes along with it.
i could be wrong though so check with the person that did this already im still in the process..
Old 06-22-2009, 01:16 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
psi drops depend on the amount of air being forced thru them. if you were to blow thru the filter with your lungs you would not be able to generate a 5psi pressure drop. it would take an extreme amount of air flow (air compressor) to generate that 5psi drop.
the minimal air coming out of the valve cover is not going to cause a 5psi "drop" in this filter. i'd imagine you'd see no drop at all actually.
$30 Oil Catch Can, DIY Ogredude DIY / Maintenance / Service 79 05-13-2011 11:05 AM
perrin oil catch can staypuft Performance Modifications 3 11-16-2008 12:20 AM
OIL CATCH TANK increase performance? 33lam Performance Modifications 29 11-11-2008 01:08 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
