Old 06-23-2009, 10:54 AM   #1
bronsin
bronsin's Avatar
Throttle Lag On DBW
Im noticing the DBW throttle lag on my 09 Yaris something fierce. Its especially bad in tight parking situations. You push and push on the pedal and nothing happens. When it does kick in the car lurches forward. This cant be good for the drivetrain longterm!
Has anyone come up with a fix for this?
Old 06-23-2009, 10:59 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
search the forum, its been covered about 2000 times
agreed
Old 06-23-2009, 11:19 AM   #3
hatchbackkid82
Drives: .
i never notice it, i have a manual, is it more noticeable on the auto
Old 06-23-2009, 11:24 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
yes. combine throttle lag with torque converter lag and you'd better push the pedal a FULL second before you want the car to start moving. (found this out at autocross lol)
Old 06-25-2009, 12:00 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
no joke... all you pussies just need to buy REAL cars.... manuals that is.
Old 06-23-2009, 11:37 AM   #6
bronsin
bronsin's Avatar
Theres a construction detour on my trip to work. To get around it I make an illegal left hand turn through heavy traffic. (dont worry its Camden NJ where schoolgirls get raped standing in line for the bus) When that gap opens man you gotta be QUICK! And this car is trying to make up its mind what to do. Its so much easier when I drive my 2001 ECHO!
Old 06-23-2009, 12:10 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
.........which wasn't an automatic ;)
Old 06-23-2009, 12:24 PM   #8
bronsin
bronsin's Avatar
I dont know how people drive a stick with this abortion. It must be difficult to co ordinate the throttle and clutch pedals.
Old 06-23-2009, 12:28 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
i'm not sure what the big deal is, it drives just fine (auto and manual) to me..
Old 06-23-2009, 06:05 PM   #10
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
ABsolutely NO throttle response problem with my 08 manual. Cant even tell its DBW. Maybe a reflash is needed or available. My car is stock and fast and I didnt screw up my car with Go-slow mods like headers and CAI that just ruin how it runs. I just saw chinocharles 0-60 on youtube and it was not too good. I think im in the 7 sec range easy on good gas. If i figue out how to set up the digital camera I'll make a viddy and U can see if im FOS or not.
TheSilkySmooth is offline   Reply With Quote
Old 06-24-2009, 07:29 AM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
i barely hit 6 seconds on boost lol.
Old 06-24-2009, 09:34 PM   #12
eric81
eric81's Avatar
Drives: Toyota Salesman
Same here, but I have a lot off changes, like CAI, header, muffler, and I even drilled a small hole in the center of my flutter valve to let just a tad more air in. Threw a CEL right away, but it idles the same, and is just a tad quicker on throttle response, so I don't mind. There is this little metal sensor looking thing just inside your throttle body's flutter valve. Maybe make sure it is clean? Also, check that there isn't a sucking sound when the car is idling, near the throttle body, because I noticed mine wasn't tightened down all the way, and after I did tighten it, the sucking noise went away and it ran smoother.
eric81 is offline   Reply With Quote
Old 06-24-2009, 09:48 PM   #13
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
not a sensor, just a useless piece of aluminum molded into the TB gasket (if this is what you are talking about). I cut mine out.
Old 06-23-2009, 12:35 PM   #14
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
everytime i see the dbw thread it makes me almost wanna get the blitz throttle controller or sprint booster..almost.. i had someone locally tried it on his automatic he said theres no difference..i guess that depends on how you drive ur car.
Old 06-23-2009, 03:57 PM   #15
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Mine's got nice snappy response. At very light throttle it switches back and forth between DFCO and power just above idle, but has no noticeable lag when throttle's applied. I wonder if some are feeling the DFCO kick in and thinking it's a defect?
Old 06-23-2009, 05:21 PM   #16
bronsin
bronsin's Avatar
Not sure what that is. The problem is: you push on the gas pedal and the car doesnt move until you push harder. Just how hard takes a while to figger out. My wifes 05 Camry is the same way. My 01 ECHO (cable) doesnt do that.
Old 06-24-2009, 02:20 AM   #17
Yaris Hilton
Smile
DFCO is Deceleration Fuel Cutoff. Whenever you're coasting with the engine turning much above idle speed, the fuel is completely cut off for zero emissions and zero fuel consumption. That of course drags the car down a bit faster than coasting with an idling engine. As you press the gas pedal, there's a slight free play before it recognizes that you want some power, and when the fuel cuts on it's slightly above the idle power level. You'll feel a small surge forward, and when you back off and the fuel cuts off again, there's a sudden slight deceleration. Like I said, if you're cruising slowly on level ground where very little power's needed, you'll feel it surging and dragging as it cuts the fuel on and off. That's normal behavior. The old Echo's ECU was much less sophisticated and didn't have this feature. Automatic Yarises up through about the middle of the 2007 model year didnt have it in Drive, either.
Old 06-24-2009, 03:06 AM   #18
silver_echo
ekodrvr
silver_echo's Avatar
really? my 01 5spd has dfco, and i never really notice when it switches... the only reason i am sure that i have dfco is from one of the hypermiling threads... the "shut-off" test...
i like this smiley...
silver_echo is offline   Reply With Quote
Throttle lag and response yaris-me General Yaris / Vitz Discussion 19 05-20-2017 09:02 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 04:36 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
DIY: Crosspost of how to get rid of DBW Lag! Nexus1155 DIY / Maintenance / Service 7 09-14-2007 01:26 AM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
