Old 06-23-2009, 04:35 PM   #1
Morgan
Morgan's Avatar
Drives: 07 MM LB
I blew my fusible link by accident not too long ago... but its located under the red cover with the "+" on it over the positive terminal, it just snaps into place. Pull the red cover off and you'll see 2 60A fuses and if you have no electrical systems working sounds like both of those fuses blew.
Good news is they are like $12 from Toyota, call them and ask them to order you a fusible link, describe its location and its a super simple install
* in the drawing above look under those fuses for the 60A fuses, those are like 20A (I think). The ones you are looking for are actually in the plastic and require that you replace the whole plastic connector piece. The 60A fuses are not relay-styled fuses
Old 06-23-2009, 05:05 PM   #2
From the service manual, it appears that the 2000-2002 Yaris/Echo Fusible Link was a little bit different. The Main fusible link in the picture above is the equivalent to the built into the plastic ones in the newer Yaris.
Tags
electrics, fuse blown, reverse polarisation, yaris
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
What the Yaris community needs to take the Yaris to the next level regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 124 04-30-2009 02:03 PM
