![]() Drives: toyota yaris (2 dr) Join Date: Jun 2009
hey... now that im thinking about it ... it did blow a lil cold but not as cold as i wanted so i put more freon... i think i put to much it there.
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
just bite the bullet and have a tech fix it... i don't know about your area, but try to check if there is a training environment in your area... they might be able to fix it for MUCH less than any other shop would... there may even be a toyota t-ten program in your area...
the reason i bring that up is because i am in the t-ten program in my area...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
#3 | |
I have a recharge kit that has a gauge on it, which is really the only safe way to recharge one yourself. The recharge kit with the gauge was only about $10 more than one without. The correct charge for the Yaris (measured on the low pressure side, where you charge it) is 0.15 to 0.25 MPa, which equals 22 to 36 PSI. |
#4 | |
ekodrvr
ekodrvr
<------------ currently in the toyota t-ten training program if that makes more sense...
ekodrvr
two year... starting brakes/susp next week for summer quarter...
| Official Mid-Atlantic Summer 2009 Meet | whooppee777 | NY / NJ/ CT / PA | 9 | 05-18-2009 12:07 PM |
