Old 06-24-2009, 02:11 PM   #1
Originally Posted by vicvs View Post
hey... now that im thinking about it ... it did blow a lil cold but not as cold as i wanted so i put more freon... i think i put to much it there.
That would make sense. The Yaris AC system does have a pressure sensor, which is used to detect high (>455 PSI) or low (<28 PSI) pressure on the high pressure side of the system.
I have a recharge kit that has a gauge on it, which is really the only safe way to recharge one yourself. The recharge kit with the gauge was only about $10 more than one without.
The correct charge for the Yaris (measured on the low pressure side, where you charge it) is 0.15 to 0.25 MPa, which equals 22 to 36 PSI.
Old 06-24-2009, 02:36 PM   #2
silver_echo
ekodrvr
silver_echo's Avatar
i would hope that that psi range is when the a/c is operating... not a static pressure...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-24-2009, 02:42 PM   #3
Correct (and good point). Automotive AC is always checked/charged with the engine running, transmission in neutral, and AC on.
Old 06-24-2009, 02:44 PM   #4
silver_echo
ekodrvr
<------------ currently in the toyota t-ten training program if that makes more sense...
Old 06-24-2009, 03:10 PM   #5
Cool. Which program are you doing (one year, two year, associates, etc.)?
Old 06-24-2009, 03:14 PM   #6
silver_echo
ekodrvr
two year... starting brakes/susp next week for summer quarter...
Official Mid-Atlantic Summer 2009 Meet whooppee777 NY / NJ/ CT / PA 9 05-18-2009 12:07 PM
