Old 06-25-2009, 11:05 AM   #1
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
The car is 5.5 months old and has 15000 miles on it, so the battery and everything else should be fresh.
As for the tapping and releasing. The ECU takes over the starting process. The key is merely a signal, unlike other cars where you are in control of how long the starter stays in. It's not so much a tap as just a very short time spent in the start position, but I really doubt that's the cause since it goes through the whole process of continuing to crank for 3 or 4 seconds until it starts.
twowheels is offline   Reply With Quote
Old 06-25-2009, 12:23 PM   #2
1stToyota
1stToyota's Avatar
It's real simple...stop the taps long enough to see if the problem persists. I've never heard of anyone doing the tapping method and don't know what the advantage would be if engine continues to crank 3 or 4 seconds in the run mode; I've never needed to crank mine more than 2 or 3 seconds with the ignition in the start mode.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 06-25-2009, 04:33 PM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
It doesnt make a difference if you hold it or if you just turn to start and release.
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
