![]() Drives: SRT4 Join Date: Mar 2007
The head lights still work but when they are on I get no dash lights at all the hvac nor speedo light up at all. And yes I played with the dimmer switch to make sure that it was in a postion where they should work and nothing. Any idea where and what to check. I checked the fuses under the hood and they were all good. Also I noticed that if the lights are on and the door is open with no keys in it does not give me that warning buzzer either now.
Thanks for any help you can give. |
#2 | |
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
ekodrvr
yes that area, and no thanks needed... i just happened to be online... i had the same thing happened when i accidentally jumped the wrong wire for my aftermarket foglights... lost all inside lights at once...
cool will go and pull and check them and report back what I find.
ekodrvr
now i have a slightly stupid question... were you doing anything under there when they went? if not, there might be an issue that would need to be looked into to make sure that it won't toast any more fuses... if that is what it ends up being...
just went over the 36,000 mile mark so no warrenty on something like this. and I do not feel like paying the bend you over prices they charge just to look at things. but I might go in tomorrow and see if they have any ideas the head guy seems pretty cool and feels bad for some problems we have had so he might have some ideas for us to check out. I guess I will try and find my circuit tester and check to make sure that the fuse is not bad and just looks ok, as well as check relays and such. Man just one I would like to have a summer hell a year where I work on a car only because I want to and not need to LOL
#8 | |
ekodrvr
#9 | |
finaly found the fuse panel that the smurfs they hired to hide it put it. I keep looking at the main block behind the cubby hole had no idea you had to pull a panel off the btm of it then use voodoo to get in there. 6' 280lbs does not make for easier fuse pulling LOL |
#10 | |
ekodrvr
and what the heck is up with the werid size fuse hardly anyplace has them let a lone know what they are.
#12 | |
And, at least they gave you a brake pedal as a headrest for changing fuses... |
#13 | |
| Question about lights | kaymm | General Yaris / Vitz Discussion | 4 | 04-20-2020 09:10 PM |
| BIG driving lights.... how? | jonismyname | Cosmetic Modifications (Exterior/Interior) | 22 | 09-30-2010 07:54 AM |
| LEDs to replace interior lights: Which ones? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 57 | 04-28-2010 01:44 PM |
| RS Lights .... reflector needed... | YAR1S | General Yaris / Vitz Discussion | 8 | 03-13-2009 04:41 PM |
| Smoke your own tail lights | ChinoCharles | Cosmetic Modifications (Exterior/Interior) | 9 | 01-15-2007 11:00 PM |
