![]() Drives: SRT4 Join Date: Mar 2007
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
yes that area, and no thanks needed... i just happened to be online... i had the same thing happened when i accidentally jumped the wrong wire for my aftermarket foglights... lost all inside lights at once...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
cool will go and pull and check them and report back what I find.
ekodrvr
now i have a slightly stupid question... were you doing anything under there when they went? if not, there might be an issue that would need to be looked into to make sure that it won't toast any more fuses... if that is what it ends up being...
#5 | |
then yesterday I put in a new radio had the correct plug in's and everything worked fine when I tried it out before sealing it back up. Everything played right all the lights worked that I could tell then when night came noticed that there was no lights. the guages still worked but no lights for hvac and speedo. took out the radio and pluged back in the stock one and still same stuff happening. just checked and the 7.5 and 30 are fine looking when I pulled them out. |
ekodrvr
ok then well at this point i am stumped.... is this in a yaris? are you under warranty? if you are under warranty, take to dealer and tell them what the issue is...
| Question about lights | kaymm | General Yaris / Vitz Discussion | 4 | 04-20-2020 09:10 PM |
| BIG driving lights.... how? | jonismyname | Cosmetic Modifications (Exterior/Interior) | 22 | 09-30-2010 07:54 AM |
| LEDs to replace interior lights: Which ones? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 57 | 04-28-2010 01:44 PM |
| RS Lights .... reflector needed... | YAR1S | General Yaris / Vitz Discussion | 8 | 03-13-2009 04:41 PM |
| Smoke your own tail lights | ChinoCharles | Cosmetic Modifications (Exterior/Interior) | 9 | 01-15-2007 11:00 PM |
