Old 06-25-2009, 05:58 PM   #1
2bad4u
Drives: 06 Toyota Vitz RS
Yes I have a torque damper and it does give you a bit more kick in rapid shifting with less motor movement but a lot and I mean a lot more vibrations at idle when it is more noticeable.
2bad4u is offline   Reply With Quote
Old 07-06-2009, 01:23 AM   #2
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
i just install it... and i dont feel any vibration on idle...
a question here... i heard from somebody that when you finish the installation you need to adjust it for get it more rigid??
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
