Old 06-25-2009, 06:07 PM   #1
silver_echo
ekodrvr
silver_echo's Avatar
now i have a slightly stupid question... were you doing anything under there when they went? if not, there might be an issue that would need to be looked into to make sure that it won't toast any more fuses... if that is what it ends up being...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-25-2009, 06:42 PM   #2
AlanSRT4
Drives: SRT4
a few days back the dealer went in to fix a noise in the fans turned out a napkin got sucked in from the glove box. but do not remember driving it at night after that.
then yesterday I put in a new radio had the correct plug in's and everything worked fine when I tried it out before sealing it back up. Everything played right all the lights worked that I could tell then when night came noticed that there was no lights. the guages still worked but no lights for hvac and speedo. took out the radio and pluged back in the stock one and still same stuff happening.
just checked and the 7.5 and 30 are fine looking when I pulled them out.
AlanSRT4 is offline   Reply With Quote
Old 06-25-2009, 06:48 PM   #3
silver_echo
ekodrvr
ok then well at this point i am stumped.... is this in a yaris? are you under warranty? if you are under warranty, take to dealer and tell them what the issue is...
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 01:44 PM
RS Lights .... reflector needed... YAR1S General Yaris / Vitz Discussion 8 03-13-2009 04:41 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
