Old 06-25-2009, 08:25 PM   #1
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Attach your lighting wires to the fuse panel,there is a open spot on it that has 12v,use a tester and you will find it right away.then unhook battery and install your lighting.....never splice in to a power source already in place in a car,it jsut leads to shorts,fires,and big pains in the butt.
As for the airbags......no worries unless you start cuttign out wires under the dash,they are harder to make go off than you think......most are identified with yellow plugs.....but if you just use the fuse panel to make connections or the battery to make connections you are good.
Yaris review from 2006..lol rningonfumes Off-topic / Other Cars / Everything else Discussions 10 12-02-2008 02:05 AM
