Old 06-25-2009, 09:59 PM   #1
Originally Posted by AlanSRT4 View Post
and what the heck is up with the werid size fuse hardly anyplace has them let a lone know what they are.
Actually they are easier to find than you'd think (at least around here). Before you replace the fuse make sure that you connected the dimmer wire from the Yaris's harness to the right place on your headunit's harness. That is most likely what popped the fuse in the first place.
And, at least they gave you a brake pedal as a headrest for changing fuses...
Old 06-29-2009, 11:22 AM   #2
AlanSRT4
Drives: SRT4
You were right the dimmer from the factory set up does not have anywhere that I can see to connect to the aftermarket one so I just capped off the wire and no more pop fuse.
AlanSRT4 is offline   Reply With Quote
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 01:44 PM
RS Lights .... reflector needed... YAR1S General Yaris / Vitz Discussion 8 03-13-2009 04:41 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
