Old 06-26-2009, 03:50 PM   #1
wouterw
Drives: Toyota Yaris 2006
Thank you for clearing that up! Very much appreciated.
I'll buy the cheaper 180mm wide part then.
What about the height?
I want to install a Kenwood DNX5220BT double DIN headunit.
This headunit is 182mm wide and 112mm high; will this fit into my yaris when I use the PZ489-B0330-00 panel?
wouterw is offline   Reply With Quote
Old 06-26-2009, 09:50 PM   #2
The height of the opening is the same from both trims (and both are correct for double DIN).
Those measurements include the removable trim ring. You would either have to remove the trim ring or push the unit back a bit in the mounting brackets (which requires grinding down 6 bumps on the brackets).
Old 05-13-2013, 05:38 AM   #3
bikeshox
Drives: 07' Sedan
Am I correct saying PZ489-B0330-00 will not fit the sedan (hazard button in the middle)?
bikeshox is offline   Reply With Quote
Old 05-13-2013, 07:55 AM   #4
Correct. There is not an OEM equivalent 180mm trim piece for the sedan.
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
2006 Toyota Yaris 5dr. LiftBack Lowering Springs yaya Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 05-14-2009 01:38 AM
