![]() Drives: 08 Yaris 3 door 5MT Join Date: Jun 2009
Nevermind about the clutch switch figured it out, for the jumper.
But for running the wires for the stock switch you would connect to the blue wire for the positive then just run a ground correct? |
#2 | |
If you do the clutch switch bypass for testing, just make absolutely sure you don't press the clutch pedal while in cruise mode. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
