The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
Just the Low Pressure line. If you did the other, smaller line, you're making it hotter.
The larger line should be insulated, only. Run your A/C for about 2-3 minutes and then touch the lines. The one that is cold to the touch should be the one that is insulated. Thats carrying cold air into the cabin. The other line is sucking hot air out of the cabin. Let that sucker air out! Check my DIY that I posted for a better image--LINK |
