Old 06-26-2009, 11:38 PM   #1
texkid
The one with cheese on it
Drives: '10 Corolla S
Update:
Yes, I had the circulation backwards.
However, I did some more research. Insulating the high pressure side will not improve cooling. Some mechanics sites say it'll do nothing....others say it'll put more pressure on the compressor, and blah, blah, blah.
Personally, I have not seen ANY positive results on insulating the High Side. In the meantime, I am going to research for insulation that withstand higher temps.
texkid is offline   Reply With Quote
Old 06-27-2009, 12:33 AM   #2
auxmike
auxmike's Avatar
Those foams you installed are in the vicinity of the very hot exhaust manifold.
212F is what water boils at. It's not really that hot when thinking in terms of an engine.
I'll pass on this one myself....
Old 06-05-2010, 10:40 AM   #3
metalshark
MetalShark
Drives: 2008 Yaris LB
Insulating the small line.
Originally Posted by texkid View Post
Update:
You don't want to insulate the High pressure line. Doing so will cut the sub-cooling of the High pressure liquid returning from the condenser and will decrease efficiency and mileage as a consequence.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 06-05-2010, 11:29 AM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I think if it would make a big improvement, the factory would've already done it.
Old 06-05-2010, 12:47 PM   #5
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
That's why I hesitated and waited so long to do it... My thoughts were like yours. However, summer heat is just around the corner, and a FEW degrees make a big difference when you're just above the "comfort zone" temp wise...
My Co-Worker was also skeptical, but after we went to lunch in my car, he decided to do it on his Tacoma as well, and even on his wife's car too. We FELT and SAW the difference and figured it could translate into a better fuel effeciency rating if the compressor would not kick in as often.
At any rate, I like the feel of the colder air blowing on my face while I sit in traffic, waiting to move 15 feet more before the light changes.... LOL
bobolinko is offline   Reply With Quote
Old 06-05-2010, 09:30 PM   #6
Yaris Hilton
Smile
Yeah, any improvement's a good thing. Gridlock in summer is grim without AC. Especially when straddling a big air cooled Harley engine.
Old 06-07-2010, 12:27 AM   #7
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Just did it to my car over the weekend and I notice a small difference. It is in the high 80's so I will check after this week and see how it does. Fairly easy to do.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
