Old 06-29-2009, 10:46 AM   #1
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
There could be a carriage difference between the Yaris design sold in the US and the Yaris sold in other countries. For example of known differences between models, Toyota offers different size motors, and a diesel motor, in Europe, than are not offered in the US.
Plus there are import restrictions between the US and Canada because of different emissions standards.
So there could be enough differences between the US model other models that make towing with the US version unsafe.
Since Toyota provides a towing loop bolt for the US model of the Yaris, and recommends that tow truck operators not tow the US version of the Yaris using the under carriage, because of how light the under carriage is on the US model of the Yaris, Toyota may view the US version of the Yaris to be unsafe to do any towing.
If you decide to tow, with make sure that you have maximum automobile insurance coverage available.
ellenbetty is offline   Reply With Quote
Old 07-06-2009, 03:14 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
Honestly, what you said is just speculation here.
The cars are the same in Canada and the US build-wise, along with Europe. The most likely reason they don't want you to tow in the US is so you go buy a Tacoma or Tundra pickup instead, lol. The undercarriage being "light" is not why toyota recommends towing by the wheels, it's to prevent damage to the car and transmission. The loop bolt is not for towing BTW, it's there in case you get stuck in a ditch, and there is no access to the rear to pull the vehicle out. I put a few thousand towing miles on my AT yaris. The only time it had an issue was when I had negative tongue weight, and that tow was only a few miles in town.
Connecting wiring to small trailer charles nelson DIY / Maintenance / Service 8 04-24-2012 05:39 PM
Trailer Hitch Wiring bldunne General Yaris / Vitz Discussion 1 01-30-2009 04:10 PM
What trailer electrical connector required? charles nelson DIY / Maintenance / Service 3 01-16-2009 04:51 PM
towing is just fine... twixt General Yaris / Vitz Discussion 8 06-01-2007 05:43 PM
