Old 06-29-2009, 03:10 PM   #1
There are a few threads on this issue. The condensate drain hose is plugged, causing the backup. This is very common in the spring when the trees drop all of their stuff.
You can clear it yourself using something like a tiewrap (flexible plastic item). Gently insert it into the condensate tube from under the car, and the water should come gushing out.
Old 06-13-2013, 07:00 PM   #2
geo3d
Drives: plain simple silver yaris
Clogged hose
Thanks for the tip; cleared hose with a wire hangar and here comes the water. Problem seems resolved though air is rushing in and out (not steady). Going to monitor for a few days.
Just wanted to say thanks for the tip
geo3d is offline   Reply With Quote
Old 07-04-2014, 02:16 PM   #3
grumpstain
Drives: 08 Yaris Hatchback
Shop vac did the trick
Hey guys first time poster here. Just wanted to say that just popping off the drain hose and taking a shop vac to it for less than a second did the trick of loosening the blockage, then just drained it into a pot.
I know some people think it's annoying, but it's a very quick fix if you've got a shop vac or something with similar suction. Better than poking the blockage back up into the hose.
grumpstain is offline   Reply With Quote
Old 09-01-2014, 06:06 PM   #4
Yaristrocrat
Basking in Yaris luxury
Drives: 2009 3-door liftback
Thanks!
Not really adding anything new to the discussion, but I wanted to say "Thanks" to everyone for your instructions and photos on how to deal with this problem. I just experienced it for the first time today, and using the info in this thread, I believe I've corrected the problem. I unplugged the hose and ran a hanger into it, then the water flowed forth. I plugged the hose back in and a nice pool of water soon formed under my little Bayou Blue pal. We shall see how things progress in the next few days.
Again, thanks for the help!
Yaristrocrat is offline   Reply With Quote
Air Conditioner kick-in?? churp General Yaris / Vitz Discussion 5 05-26-2007 08:43 AM
Air Conditioner Noise Cathy General Yaris / Vitz Discussion 16 05-08-2007 02:08 AM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
