Old 07-03-2009, 05:23 PM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Did the a/c cooling improve?
Old 07-03-2009, 05:49 PM   #2
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
Not sure yet, as I only checked for clearance with the insulation.
I did check my wife's Baja, and the sister-in-laws Aveo today - neither of them has any insulation whatsoever.
I can't see how this mod could possibly hurt anything at all! (other than a few cuts and bruises.)
andaconda is offline   Reply With Quote
Old 07-03-2009, 06:26 PM   #3
auxmike
auxmike's Avatar
Yeah, looks like you hit something sharp! Mabye a glove would help prevent this for the others???
Old 07-03-2009, 06:33 PM   #4
andaconda
andaconda's Avatar
Are you kidding me? I can't work with gloves. I get cut up if I even look at the underside of a car.
Besides that --- what's a little mod without a little blood?
Old 07-03-2009, 07:55 PM   #5
texkid
The one with cheese on it
Drives: '10 Corolla S
That is definitely true. Besides, gloves were useless to me when I was smelling some burned arm hair.
If you don't mine, stick a meat thermometer in the air vent and let us know what temp you're getting when driving.
I noticed that mid-morning and after around 17:00 my temps go as low as 37-ish degrees.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-04-2009, 02:12 PM   #6
andaconda
andaconda's Avatar
When I take it out of the garage on Monday, I'll take its temp.
Old 07-06-2009, 06:44 PM   #7
andaconda
andaconda's Avatar
Well I checked it on my 15min way home from work. Outside air not recycled air. Fan was on 2. Temp hung right around 40 degrees.
Temp increased to 42 degrees when I turned the fan on 4.
I wish I would have taken it's temp before the mod.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
