Old 07-03-2009, 08:38 PM   #1
firebob
Drives: 09 yaris
Originally Posted by andaconda View Post
Besides that --- what's a little mod without a little blood?
If there’s not blood then you didn’t do anything.
I truly don’t think there’s a big issue with the AC as it is stock. I have looked at other cars still sitting on the lot and they use metal lines that are not insolated for part of the run also. I have driven plenty of other cars, SUVs, and trucks but I think the Yaris is as good or better with it’s cooling capabilities. Could the problem start after mods have been done that changes the temp under the hood?
If you have your AC on and you’re not running the fan wide open then why run the compressor and make the motor work harder for no reason?
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 07-04-2009, 11:22 AM   #2
PatrickJohnson
Drives: 2008 Yaris LB
The cooling was good before, but after doing this mod and driving for about a week, it is a night and day difference.
PatrickJohnson is offline   Reply With Quote
Old 07-04-2009, 01:52 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Your tetanus shots up to date, Andaconda?
Old 07-04-2009, 02:17 PM   #4
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
I don't believe I've ever had one???
andaconda is offline   Reply With Quote
Old 07-05-2009, 03:07 PM   #5
Yaris Hilton
Smile
If you grew up in the U.S. since about the '50s, it's unlikely that you haven't had a primary tetanus immunization series. Required to go to school. But you're supposed to get a booster every 10 years, just in case you do stuff like gouge up your hands while working on your car. Lockjaw's bad stuff.
I suppose this is DIYer maintenance/service. :D
Old 07-05-2009, 03:13 PM   #6
supmet
Drives: 2007 4 Door Yaris
Hmmm, you are correct, the cdc website says DTaP is required across all 50 states, but I only remember getting tetanus shots post-injury. Maybe I just don't remember because its a combo vaccine for school requirements, and just a tetanus shots after injury.
Old 07-05-2009, 06:18 PM   #7
texkid
The one with cheese on it
Drives: '10 Corolla S
Rule of thumb is that if you don't remember your last DTaP shot then its time for booster.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-06-2009, 07:00 PM   #8
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Did all but the area by the pullies. I put aluminum rap around the insulating foam and lightly tie wrapped the total. In my head ity seems cooler. Wish I had done a before after. But, can it hurt?
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 07-04-2009, 02:16 PM   #9
andaconda
andaconda's Avatar
Instead of turning the temp down or up, I'm in the habit of pressing the air "on/off" button so that the compressor will only come on when I want to cool off.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
