Old 07-04-2009, 01:52 PM   #1
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Your tetanus shots up to date, Andaconda?
Old 07-04-2009, 02:17 PM   #2
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
I don't believe I've ever had one???
andaconda is offline   Reply With Quote
Old 07-05-2009, 03:07 PM   #3
Yaris Hilton
Smile
If you grew up in the U.S. since about the '50s, it's unlikely that you haven't had a primary tetanus immunization series. Required to go to school. But you're supposed to get a booster every 10 years, just in case you do stuff like gouge up your hands while working on your car. Lockjaw's bad stuff.
I suppose this is DIYer maintenance/service. :D
Old 07-05-2009, 03:13 PM   #4
supmet
Drives: 2007 4 Door Yaris
Hmmm, you are correct, the cdc website says DTaP is required across all 50 states, but I only remember getting tetanus shots post-injury. Maybe I just don't remember because its a combo vaccine for school requirements, and just a tetanus shots after injury.
Old 07-05-2009, 06:18 PM   #5
texkid
The one with cheese on it
Drives: '10 Corolla S
Rule of thumb is that if you don't remember your last DTaP shot then its time for booster.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-05-2009, 08:11 PM   #6
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Lol, indeed.
Ive been lucky having cut myself, not so lightly, several times in the last two years, on not so clean metal, and havent had lockjaw yet, even though my tetanus is wayy overdue.
Old 07-05-2009, 08:30 PM   #7
texkid
Originally Posted by AlexNet0 View Post
Lol, indeed.
That's why its good for 10 years.
Go ahead and treat yourself to a nice DTaP shot and enjoy the next 10 years of bumps, scrapes, and cuts. You know, the way God designed us to do.
DIY: A/C Insulation
Old 07-06-2009, 08:21 AM   #8
andaconda
andaconda's Avatar
Ah, come on now. Suck it up, and toughen yourselves up!
Old 07-06-2009, 02:59 PM   #9
texkid
My, my...
You can't really "toughen yourself" out of lock-jaw. In fact, that is the first sign that you should get treated. Why? I am glad you asked.....After your jaw locks up, your neck muscles and the muscles you use to facilitate in breathing begin to "lock-up". Once that happens, which are the late signs of a tetanus infection, you can't scream for help much less breathe effectively; putting you into respiratory arrest and then....well you get the rest.
Hence why it is important to be up to date with your vaccines. Besides, can you imagine what our friends will say? "Did you hear about 'so-and-so'? After he modified his car he died of tetanus. Who wants dibs on this car?"
By the way, do you wrap that big bubble like thing in between the tube by the ECU? What is that for?
Honestly, I don't know what it is for. All I know is that it is wider and needs more material to wrap. It did make about a 3 to 5 degree difference when I wrapped it up. And yes, it was mentioned in my initial post.
DIY: A/C Insulation
Old 07-06-2009, 07:00 PM   #10
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Did all but the area by the pullies. I put aluminum rap around the insulating foam and lightly tie wrapped the total. In my head ity seems cooler. Wish I had done a before after. But, can it hurt?
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
