Old 07-04-2009, 02:22 PM   #1
supmet
Drives: 2007 4 Door Yaris
I have a sedan, and to get under the ebrake -
1)Unscrew the bolts in the rear cup holder, you should be able to pop all of the trim off around below the cup holder.
2)open the center console, remove the rubber mat at the bottom, and take out the two bolts.
3)pop the bottom of the trim off under the a/c controls, and remove the 2 bolts under there.
You should then be able to pull the entire center console out. The power outlet by the ebrake might still be holding it in, but you should be able to move it around enough to get your ring. Also, when I did this, the purpose was to tighten the lid on the center console, which was popping up when I elbowed it. Tightening the four screws behind the cup holder fixed that problem.
Here's my loot from the adventure:
Old 07-04-2009, 03:02 PM   #2
AlainMikli
AlainMikli's Avatar
To do: Supercharger…
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
Parking Brake Adjustment Q's Lafiro DIY / Maintenance / Service 3 04-13-2009 08:19 PM
Parking Brake Geelmeel General Yaris / Vitz Discussion 3 06-07-2007 11:06 AM
