Old 07-04-2009, 02:24 PM   #3
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
yes remove the screw
then pop up the back
if its jammed down there they sell magnetic wand type things that collapse and expand
there used to retrieve bolts that fell in like the engine bay or what not
Most rings are non-magnetic, so the wand won't work. After removing the cover, try a piece of wire with a hook bent on the end.
Good luck!
andaconda is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
Parking Brake Adjustment Q's Lafiro DIY / Maintenance / Service 3 04-13-2009 08:19 PM
Parking Brake Geelmeel General Yaris / Vitz Discussion 3 06-07-2007 11:06 AM
