Old 07-04-2009, 06:33 PM   #1
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
Originally Posted by AlexNet0 View Post
so is there a general consensus as to what the insulating material should be? I dont want melting insulation.
As you can see on page 5 - the fifth photo down, I used copper pipe insulation that has about a 3/4 inch inner diameter. The insulation is about another 3/4 inch thick. I then wrapped it with aluminum tape for heat protection from the engine and exhaust manifold.
andaconda is offline   Reply With Quote
Old 07-04-2009, 07:04 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
so the heat tape stopped the insulation from melting? I would think that it would still heat up inside, just not as much radiant heat would make it through the tape. Im just worried that the general ambient temperature due to the close proximity to the exhaust manifold will still melt the insulation under the tape.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
